Discuss Travertine haze in the Canada Tile Advice area at TilersForums.com.
sledge90
Hello gentlremen,
I am new to tiling with travertine and have made the novice mistake of not sealing before grouting. I have just used a rustic unfilled, chipped edge travertine and was told that sealing could hinder the grout filling and bonding with the holes. Anyway, I have cleaned most of the grout haze off using a scraper, floor buffer and elbow grease but still have a slight white haze obn the stone. I was wondering if anyone could advise me on the following:
  • I was told that a floor polishing pad could push the grout haze further into the material after I was told to use it. Is that true?
  • Will the colour of the travertine change at all when I do seal the tiles?
  • Will this haze come out with a scotch bright pad for a floor cleaner if I try again?
Pictures are avilable if needed.
Regards for any help.
Reply to Travertine haze in the Canada Tile Advice area at TilersForums.com
Hi all. After living in my property for over 7 years I've recently discovered the type of tile...
Hi, I did a limestone floor for a customer which I washed and sealed, then grouted 24 hours...
  • Sticky
Hi guys, Please help me. Really having a nightmare here. Just moved into a new house and the...
5K
Tilers Forums on FB
