Guest viewing is limited
Discuss Travertine in a shower in the UK Tiling Forum area at TilersForums.com.
GaryS
Sorry guys you are probably fed up answering questions about these tiles already but as a novice i could do with some advice.
Both myself and the missus really love the look of travertine tiles however as we are considering this for a bathroom including a shower area, we have been advised to use an imitation rather than the real stone tile.
The info we have at the moment is that travertine is not really suitable for a shower area as water will soak through to the plasterboard beneath.
I am aware these tiles require sealing, though not sure what other preparation is required.
Any advice on how to prep so we don't have problems later will be greatly appreciated.
Thanks in advance.
Gary.
peckers
Firstly you need to find out the weight of the tiles per M2! As they may be too heavy for plasterboard!
But To be honest with you I would remove the plasterboard any way and replace with a tile backer board!
As with any tiling the correct work is started with the preparation!
I would tank the shower area to be tiled!
Use a good quality white flexible adhesive and flexible grout! Not a DIY own brand!
Before setting the tiles remove any dust from the back of the tiles, with a damp sponge.
Back skim the tiles with adhesive to fill any voids in the tile if there are some.
Be sure to work cleanly washing any adhesive from the face of the tiles as you go.
After tiles have set in the adhesive Apply a good quality sealer.
Then grout using a flexible grout.
When dry buff off haze grout residue etc.
Apply another coat of sealer and another one if it will take it.
be sure to seal internal corners and against tray with a good quality silicone.
If the preparation work is done correctly and they are sealed correctly then you will have no problems.
Aftercare to keep them looking nice wash them down with a proper stone tile cleaner
Dont use domestos, bleach, Mr muscle etc as this eats into the sealer tiles grout etc and will ruin it over time.
hope this helps :thumbsup:
GaryS
I had a tiler in to do the small bathroom downstairs today 20 years in the trade so he told me and he still cant get tiles flush on a flat wall surface so he wont be getting job of doing the main bathroom. granted its not as bad as some I have seen but when a so called professional walks away from a job that that you can do better yourself on you got to wonder. I am even going to have to cut back some of the tiles as he left them overhanging where the door checks go despite being told about it before he started.
rant over sry guys
oh for those of you that have not got one yet buy a fein multimaster its an amazing tool that will save you a lot of hassle and allow you to get a much neater finish around door checks
Reply to Travertine in a shower in the UK Tiling Forum area at TilersForums.com
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
  • Sticky
