Discuss Travertine internal corners in the British & UK Tiling Forum area at TilersForums.com.
ohhnoo
I recently tiled my bathroom with 610mm x 405mm travertine and wondered if I should have used Silicon on the internal wall corners. I used ivory Silicon where the floor meets the walls but as the grout is flexible I thought it would be ok for the wall corners. Theres no cracking or anything just wanted to check as I've read a few posts about expansion etc. Three walls are brick with moisture resistant pb and the other is a stud wall.
DHTiling
Hi and morning..
Internal corners are expansion and contraction joints, small amounts of either can put stress into an internal joint and thus should have some degree of flexibility, that is where a Silicon joint comes in ,as it will compress with expansion and stretch with contraction of the walls substrate..
Some manufacturers having silicones that match the grout colours, Mapei are one of them and their silicones are acetate free and ok for stone work.
peckers
If they are in a wet area you can rake out the grout and Silicon it. If its a dry area then if and when it cracks you could just regrout it
As the walls are of differen't constructions then different rates off expansion are going to happen imo then you should leave expansion joints in the internall corners weather it be wet or dry areas, and grout weather flexible or not does not allow for this.
Silicon joints do if a gap has been allowed for in the internal corners:thumbsup::thumbsup:
Reply to Travertine internal corners in the British & UK Tiling Forum area at TilersForums.com
Hi all, As per the title, my tiler has grouted the internal corners of our new shower enclosure...
  • Sticky
I've seen lots of posts on internal corners in a bathroom but am still confused as to what to do...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
