Discuss Travertine on backer board in the British & UK Tiling Forum area at TilersForums.com.
F
fin
I am about to lay a small number of honed and filled travertine tile 400x400 on small bathroom floor 700x1450.This on backer board on top of flooring grade mdf. I intend to use Ardex S 16 fastset and a suitable grout and finish with a few coats of HD impregnator. There is a need to get the WC working again asap. The questions are: is this ok?, Should I fill any holes in the back of the tile with adhesive? What colour grout and what brand, was thinking Mapie Beige?? And is HD impregnator any good as the others seem murderously expensive. Thanks
DHTiling
Hello and welcome...
I have some questions first before going any further...
Flooring grade mdf...how thick is this and what is it laid onto..?
Who advised the ardex S16...? it's not suitable for timber floors.
Do you mean HG impregnator....?
And what backer board is it.?
F
fin
18mm laid on to joists with 28cm centres and then Cembrit Blunn Special Performance board
I meant HD stone impregnator, Its Dutch I think.
I had assumed that the backer board would remove the need for flexible adhesive which would be needed for ply for example.
DHTiling
You can get LTP at good prices...i personally don't like HG, they tend to leave a sticky film and is hard to buff off...
LTP mattstone is great fors tone and leaves natural matt finish or LTP colour intensifier and stainblock will darken the stone slightly and enrich the colour..
The sealers can be bought from Tile giant.
DHTiling
Sorry about the links
Is HG OK or should I get a mortgage an shell out on some lithofin stainstop plus colour intensifier
So its flexible adhesive - is there a additive to reduce hardening time?
Just buy a standard setting flexi adhesive...
Keraflex maxi has a bucket life once mixed of around 8 hrs, so plenty working time.
Reply to Travertine on backer board in the British & UK Tiling Forum area at TilersForums.com
We have a dormer constructed, passed by building control, but they have obviously just...
Installing tiles 400x600 over an exposed exterior cement screed - it has 20mm fall over 2300mm...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
