Discuss travertine on stud walls in the British & UK Tiling Forum area at TilersForums.com.
mscg
I am concerned about the weight loading with travertine on skimmed plasterboard to a stud wall. Interested to know options available - could I go with extra wall fixings or replace plasterboard to ply or backer boards What experience do you guys have and what is the shear weight for plasterboard I believe someone mentioned 20kgs in an earlier post
Time's Ran Out
Can I ask the question is this weight allowance taken when the plasterboard/plaster is in the horizontal position and the weight of the tile/adhesive etc is in the downward motion - ie as stuck on the ceiling.
Or is it taken when the weight of the tiles+ to the vertical wall are stacked on top of each other and in which case when fixed using my plumb levelling system - the weight is stacked on top of each tile in perfect symmetry.
I wonder if there is a measurement of force that is required to pull 20kg - 32kg of a vertical wall surface!
Just a technical thought!
Here to be educated!
Used to be known as Timeless John.:thumbsup:
diamondtiling
Very similar thread to the one where i'm getting my butt chewed off, If the walls are solid and with no give then I really cannot see the problem, tiles are supported from the floor up, I have never known tiles to fall off because they are too heavy. Inspect the walls throughly and if you have any misgivings then carry out the appropriate remedial works, unless you have an architect on site and then obviously he/she knows best.
:mad2::mad2::mad2:
diamondtiling
timeless has just taken me back to the good old days, when swan vestas could be used as more than a tool for lighting your woodbines, on the topic of spacers how long have you had yours, I mean do you keep them like I do, I have names for them, one leg joe, covered in adheshive( but he will clean up ) pete, be honest guys, when you hoover up how many spacers do you rescue for the next job? BE HONEST!!
:lol::lol::lol::lol:
Reply to travertine on stud walls in the British & UK Tiling Forum area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
I need help on what prep I need to do. I have read on the forums here and I seem to be going...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
