Discuss Travertine Wall Tiles in the British & UK Tiling Forum area at TilersForums.com.
mini17
Never used one of these sites before so not really sure what to say but here goes. We decided to buy some lovely travertine wall tiles for our bathroom. As we don't have particularly good walls we will be plasterboarding or putting up marine plywood to give the flat surface to take the tiles. I have seen somewhere that we shouldn't use plywood is that correct? do we need to ensure that the plasterboard etc. is fully sealed first before putting up travertine tiles. Bit of a novice but we were advised that they are easy to lay even as a d.i.y.er Can anyone give me a site where we can find full advice on these tiles? Many thanks
grumpygrouter
Hi Welcome to the forums. This is THE place if you want tiling information.
Ply is not my favourite substrate for a bathroom environment, it is too thermally unstable. To put stone tiles onto a wall, you need to make sure the wall is storng enough to support it. Even plasterboard is approaching the limits for natural stone. You would be better putting up a cement based backer board like Hardiebacker 500. This is ample strong enough to support your tiles and is also resistant to moisture as well.
Not sure that Travertine is "easy" for a novice, certainly a DIY novice. They all need to be cut on a wet cutter, they will also need sealing and you will need to work very clean. You will also need to use a powdered adhesive NOT bucket stuff. What are the dimensions of your tiles?
Gracer
Sorry to tell you this, but travertine aint easy to lay,it doesn't cost nearly double to lay as ceramics for nothing! I would seriously consider paying a professional to do it.
Unless you are exceptionally handy and or a very quick learner. But these tiles don't come cheap, so how much experimenting can you afford?
beanz
Berkshire
In my opinion yes, unless you fix to backerboard.
What would you expect 10mm Trav to weigh in at Grumpy? I was under the impression that up to 9mm of anything should be ok for skimmed, so i'm a bit surprised that the extra 1mm would be a problem for un-skimmed. Obviously the up to 9mm rule is a bit sketchy, so maybe i should be using a better method. Preferably something that doesn't require bringing scales along hehe!
Gracer
I don't fully understand some of the terms & proceedures you guys use over there.
I have laid up to 600 x600 travertine on walls here without an issue. As long as the walls are built properly they should take any weight you can throw at them. Our walls are built with either aluminium or pine studs and cement sheeting, usually. With the occasional brick & or rendered walls, in domestic situations.
I would like to point out that the building of the walls over here are the builder/chippys responsiblity. Reading some of these threads it seems some of you guys build your own?
grumpygrouter
If you check out this link Beanz, you will get an indication of what I am thinking.
Tiles and Adhesive Weight Per Square Metre - THE TILE SOURCE
Stone is much denser than ceramic so I tend to err on the side of caution when giving advice on here. Obviously the fixer has to make the call and the end decision is up to him/her if they want to work so close to the limits.
grumpygrouter
Cement board is only just really starting to be used more over here. Most of our construction is plaster or plasterboard (gypsum) based. This doesn't have the same strength as cement board so we need to be a little more careful.
Gracer
Ah fair enough...I don't think I'd like to be sticking heavy tiles onto gyprock either. Onto render should be fine though.
beanz
Berkshire
Thanks for the link, much appreciated. That's going straight in my bookmarks! ;)
tile55
Aswell as the tiles themselves you need to remember the addy and grout when thinking about weight issues.
Reply to Travertine Wall Tiles in the British & UK Tiling Forum area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
