Discuss travertine in the UK Tiling Forum area at TilersForums.com.
shaundaly
Hi Guys,
I done my tiling course with North East about 1 year ago. I've done loads of wall and a fair bit of floor tiling. This is in kitchens only as I am a kitchen fitter.
I have a fit to do in 2 weeks and the customer has travertine tiles. The wall tiles are 4" so they can be fitted as normal I assume, but the floor tiles are the mosaic type with different tiles in the matting.
As I have never touched this stuff before, I have a few questions.
Do you lay the floor tiles randomly or try to create a set pattern?
Do you seal tops and bottom of tilies before fitting or just tops?
Can you cut the tiles with a normal wet cutter? I have the bigger plastic plugs one. Are the mosaics easy to cut on a wet cutter?
I think the floor is concret(did not do survey) so what adhesive and grout do I use. What adhesive for walls.
I have a v notched trowel that I use for wall tiling and normal one for flooring, not sure of size but think 10mm. I got it from North East for ceramic/porcelain.
Should I prime floor and walls with BAL APD?
Any help appreciated.
Shaun
K
keraldine
Hiya
If they are on a mesh then i would follow a pattern as you will get your randomness from the way it is already laid on the mesh ,
You generally only need to seal the tops of the tiles and you can do this after fitting but before grouting and a white adhesive would prevent colour from grey adhesive bleeding through the tiles.As for cutting you should find it relativly easy on the wet cutter if the pieces are big enough to hold without your fingers getting in the way .
I would just check that the adhesive is suitable for use with natural stone but always go for white with light travertines and read the bag to see about priming as a lot of the newer versions are self priming dependant on how powdery the substrate .
The trick is just to check the bags and call the tech help lines if you are not sure of anything :yes:
shaundaly
Thanks Mate.
If I don't seal before fitting and I get a bit of adhesive on the tile when laying, could this cause a problem with staining. That's why I was thinking about sealing before laying. It's strange, some people say seal before and some say just seal after. This is what's causing my confusion.
The tiles are beige so I guess its the white adhesive as you said.
Shaun
BDS
Hi shaun i`ve just done 60 m2 of travertine floor,not mosaics but same stone and as long as you clean of any excess adhesive but make sure its white adhesive,if any residue left on use a remover theres loads on the market then seal tiles,theres lots of sealers out there as well so use as per there instructions then grout.as for adhesives i`ve used a few and find BAL the best and there always more than happy to help in anyway have a word with GazTech he can tell ya more about addy`s/primers etc etc etc good luck :thumbsup:
shaundaly
I've been spending time looking on the forum and theres so many different opinions about sealing. I should have pointed out that the tiles are the rustic type with small holes and not the smooth type. Unfilled or honed I believe its called.
Some guys are saying don't seal before grouting or the grout in the holes will not stick so I am well confused at what to do.
Is this the correct process?
Fit wall tiles unsealed, using white flexi cement adhesive. Another point, if the walls are skimmed plasterboard should I remove skim. If walls are block and have skim over undercoat plaster what then? The undercoat stuff is usuall really soft and powdery and you can scrape out with finger nails. Please advise on this as this has only just entered my head.
Seal & grout(flexi grout) or grout and seal?
Seal
Wash off.
Lay floor with same adhesive and grout.
Thanks guys.
Shaun
:stupid:
E
enduro
I always lay the tiles first then grout, then clean tiles with a floor polisher with a cleaning pad, then seal, then buff them up with floor polisher, i bought the machine on eBay for a few hundred quid, and it makes the job look so much better when finished and the customers love it as the new floor looks perfect. :thumbsup:
andy-p
heres a recent job, unfilled trav sealed before and after grouting..
Gazzer
Can you be more specific about the floor polisher and the pads you used please :thumbsup:
Reply to travertine in the UK Tiling Forum area at TilersForums.com
travertine
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 24 24.0%
    Votes: 14 14.0%
    Votes: 28 28.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
  • Tilemaster /Kelmore
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 11 11.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
