Discuss Travertine ??? in the British & UK Tiling Forum area at TilersForums.com.
McP77
Wouldn't fancy it myself. That is one heavy tile. So you know that two walls are brick and two are plasterboard stud. Do you know that these walls haven't had a plaster skim. If any plaster then safe weight goes down to 20kg per square metre. I suspect that these travertine weigh around 30-35 kg per square metre on their own.
Preparation - rip everything off. Check tiles aren't too heavy for plasterboard. If so go for aqua panel.
Adhesive - white, flexible cement based adhesive.
devonmark
If I was in your shoes I would walk away from the job if the customer wouldn't take my advice...which would be to remove all tiles and reboard if needed..guess who will be at fault if the tiles where to pull from the wall and it won't be the customers.
Go back and try to get him to let you remove and prep correctly if he won't...walk away and let someone else take the chance.
Reply to Travertine ??? in the British & UK Tiling Forum area at TilersForums.com
5K
Hi, Would you use Durabase matting over Hardie 6mm floor? Im not 100% happy with the ply floor...
Thanks for taking your time to read through this and really appreciate the support! So me and...
Travertine ???
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
