Discuss Trim for tiled wall corner - which type? in the Canada Tile Advice area at TilersForums.com.
If that angle is obtuse as it looks in your sketch it’s a simple fix.
Just come halfway down the edge of the tile and undercut it by about 45 degrees, that should bring the front edges close enough together for a grout joint, if not, come a little closer toward the front face.
Yes that’s the idea. If it’s a metro, then you may be able to achieve it with a rubbing block on the biscuit rather than having to use a grinder.Yes, maybe 135 degrees.
When you say halfway down the edge, do you mean in a fashion as indicated by the red line on the sketch below? BTW, it's a metro tile.
I'm not a professional tiler, so unfortunately I'm not familiar with the terminology. Would you possibly explain biscuit in this context?If it’s a metro, then you may be able to achieve it with a rubbing block on the biscuit
Reply to Trim for tiled wall corner - which type? in the Canada Tile Advice area at TilersForums.com
