Hello All
For good or bad (probably bad as its not a common choice) we're planning to tile around the top of the kitchen worktop. Worktop is dead level so plan to leave a 2 or 3 mm expansion gap and Silicon that.
The issue is the top of the tiled upstand. The tiles are black ceramic with raw terracota colour visible at the sides. I hadn't given it much though until now and I know its partly/mostly a aesthetic question but I still appreciate your thoughts as you probably see a lot of kitchens. Should I use aluminium tile trim or just Silicon/caulk over the top?
If trim is the way to go would 10mm be ok for 9mm tiles ? The tiles are small at 100x300mm
