Discuss Triple Shower Valve with Diverter - Tiling Preparation and access help in the Canada Tile Advice area at TilersForums.com.
joe90k
Hi All,
I am in the middle of sorting out my family bathroom, to begin with I have removed the bath, changed the original light fitting for three LED fire rated spots and am about to begin with the 1st fix.
The whole house is plumbed in 15mm Hep2O for the hot and cold supply by an unvented cylinder running at roughly 2.0 Bar. I am going to fit a Triple shower valve with diverter valve which I got from Victoria Plumb. Valve looks good in comparison to Bath Store concealed valve I have fitted before. However I after advice on mounting the valve as I have not fitted a valve in metal stud before, I have worked out how I am going to fit the valve, well sort of, it really depends on the way I finish the face of the wall. The wall in question is between the bathroom and the airing cupboard, so I plan on removing the plasterboard behind the valve in case there are any leaks in the future and because it doesn't matter if the wall in the cupboard is not covered.
The problem is that the valve is the exact thickness of the wall including the thickness of both sheets of plasterboard! So my plan was to remove a section of the front plasterboard, build the valve and all pipework on the board off the wall and then mount it up onto the metal stud, but I know ply is not a recommended material for tiling onto, I am going to tank the walls around the shower but obviously I will be using 12mm ply and 12mm plasterboard next to each other and tiling over the top. Some tiles will bridge the gap too.
The only other option I have is fixing the valve backwards through the mounting lugs on the back of the valve to batons screwed to a sheet of green plasterboard and mount that up. Any advice is greatly appreciated, I am not going to bother with cement board as I am only fixing 7mm tiles so the weight will be well under what the plasterboard can take.
I'm going to use Dunlop Rapid Set
Re: Triple Shower Valve with Diverter - Tiling Preparation and access
Hello & :welcome: Joe.
The shower valve should have min-max measurements for installing in stud walls usally 60-100mm, check manual for these.
The valve should be brass bodied and installed correctly you needn't worry about needing to get to it all servicable parts shoul be accesable from the face plate.
Consider 12mm ply behind the valve to screw to, either fixed to the plasterboard or built out in the airing cupboard. hope this helps.
Reply to Triple Shower Valve with Diverter - Tiling Preparation and access help in the Canada Tile Advice area at TilersForums.com
Tilers Forums on FB
