Discuss trouble with encaustic tiles cracking. in the British & UK Tiling Forum area at TilersForums.com.
John P
We have recently had laid a kitchen floor with encaustic tiles from fired earth (20mm x 200 x 200), they went down on a stable slab that had had tiles on before. the encaustic tiles have cracked in places almost along contour lines, in multi directions. They are still in place, but deteriorating, has anyone had trouble with encaustic cracking? we are in a strange triangle between our builder, sub contractor and tile provider. Experience and anecdote welcome. Many thanks
John P
encaustic tiles cracking: Pictures of the floor in question
pics of the floor in question.
If we lift a tile - then that's the lot coming up, and want to know who is at fault... thanks for thoughts so far - the 'contour' is slight - it is flat, but micro deviations that the tiles seem to have snapped around, and settled. still don't know the adhesive make. the levelling was from 0 - 15mm in some areas/
someone mentioned expansion joints, tiles go as far as just under base units but not to walls of room - tile edge to walls was concrete.
DHTiling
Looking at the pics... it is a similar pattern to what SLC makes when it fails..
The pattern of the cracks is what i mentioned earlier and it seems to confirm the SLC has failed underneath and stress cracks have transferred to the tiles..
Perry
if it has come through as stress cracks because of the slc i presume the tiles will be hollow and if one would take a tile should it come up easy ? never had much to do with encaustic tiles that i can remember but had a lot to do with fired earth in the past and always found them ready to blame everybody else and never take responsibility them selfs IMO
Richard Edwards
I'm puzzled as to why you or Fired Earth are reffering to these tiles as Encaustic Tiles ? Encaustics are normally a two or more coloured tiles ie Victorian Encaustics where the coloured (up to 6 different colours on the same tile) design is made throughout the surface of the tile using different coloured clays and slips in the firing process.
Are these tiles Unglazed Porcelain or Unglazed Clay Tiles in one colour.
Richard Edwards
These tiles are Not Encaustic Tiles - Check Wikipedia
Not that this helps with the problem - Lift a couple and the reason will be obivous -
Suggest a joint meeting at a specific time and all parties involved stand around the tiles and lift a couple. No argument then ! Hope all envolved are professional and responsible and if so the guilty will hold hand up and offer to fix it.
Sorry with two separate messages - hit the Return button by mistake !!
Reply to trouble with encaustic tiles cracking. in the British & UK Tiling Forum area at TilersForums.com
Hi all, I was hoping to get some input/help on this situation. Background: We had 12 x 24"...
Hi All, I'm on with tiling all my downstairs rooms with 60cm x 60cm High Gloss 9mm tiles. All...
6K
Dear TilersForum Thank you so much for the outstanding advice and expert information over time...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
