Discuss trouble withardex 6001 with underfloor heating in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
Hi Julian, welcome to the forums. Would you be good enough to say hi to everyone in the "new members" section and tell us a bit about yourself. Cheers.
I have never used 6001 but it should be fine for the application you mention. What is the substrate and was the heating level increased gradually when it was first switched on after tiling?
Grumpy
grumpygrouter
6001 is not suitable for timber substrates julian..should have been 7001 timber system................there must have been to much movement for the 6001 to handle...............
Not sure if that is the problem though Dave. Looking at the Ardex manual, if the tiles are not directly stuck to the timber, ie there is insulation board or in this case Ditra, then 6001 should have been fine. Otherwise deffo 7001 straight to the tiles.
Would like to see what order the stuff had been laid. If it is as given above I don't think that is correct. The Ditra should have gone over the UFH surely?
Grumps
grumpygrouter
Just checked the Ditra installation pdf.
Schlüter​
®-DITRA is also recommended
for uncoupling of radiant heated floors
consisting of thin electric heating mats.
Schlüter
®-DITRA may be installed either
above or below the heating mat. However,
the uncoupling function is more effective
if Schlüter
®-DITRA is installed above the
heating mat.
Grumpy
Interesting this...........
Grumpy
Reply to trouble withardex 6001 with underfloor heating in the British & UK Tiling Forum area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
