Discuss Trowel size advice required in the Canada Tile Advice area at TilersForums.com.
I am a general DIY'er and have previous experience tiling bathrooms and kitchen floors.
My question is which trowel should I go for on a 30cm x 60cm porcelain tile (same tile, different colour) going on a tanked walls (two plasterboard, 2 plastered) and floor (new T&G with 6mm plywood 10cm screw spacing). I have never tiled using porcelain and this size.
Also which hole cutter would you use, I need to cut for 15mm pipes and 50mm for the shower bar/waste pipe.
Any advice would be greatly appreciated, many thanks in advance.
6mm ply is a big no no. Use a suitable backer board.
8mm to 10mm trowel will suffice
Thanks for the advice.
With respect to the floor, I am reluctant to remove and replace the 6mm ply as it has already been tanked. The ply is screwed down at 10 cm intervals onto brand new T&G, this is also well screwed down. What are the risk if I continue and what are my options?
Also WRT trowel size, should I use a half moon trowel for the floor and square for the walls?
Reply to Trowel size advice required in the Canada Tile Advice area at TilersForums.com
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
London
What member type are you?
  1. Homeowner
Business Name
Mr James Bellingham
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
