rj1884
Hello. Quick question if possible please. Im starting a kitchen for which runs into a hallway. The floor is ok with regards to levels. My question is as its not completely flat should I use a notch trowel with the width 20mm and the depth 10mm half moon shaped or wil this be to much or a 10x10 square notched trowel. If neither would suffice which would you guys use.
many thanks in advance.
