charlie1
What do you do?
mine is left hand bucket trowel on to right hand flat edge of trowel and plaster on to wall on vertical motion from batten up, repeat till whole wall is done at a height of 400mm up from start, then serrate in a vertical line enough for one course then slip up and over excess adhesive at the top so it stays on the wall ready for next serration. Then i make one long horizontal serration with both hands for better control of angle. Then with corner edge of bucket trowel i remove excess that's touching batten or top of previous course just to keep it clean. Then, cut in bucket after removing adhesive. Then use the large mound of adhesive sticking to wall to back butter tiles.
i think its very important to develope an efficient troweling technique. A good trowelling technique can save you time not only when sticking the tiles but also cleaning.
