Discuss Tub surround problems in the UK Tiling Forum area at TilersForums.com.
mnye00
I am tiling a shower surround (walls) in my basement and have installed the cement board and thought I was ready to go... wrong.
It looks like the studs behind the board are a little out of alignment and this is causing some big dips. If I hold a 4' level against the back wall, the left had side is about 1/4" recessed in some places. How can I solve my problem. Can I simply apply thinset to the wall in all the low places until it is all on the same plane?
Any thoughts?
mnye00
1/4 inch is nothing like macten said, use some rapid set to get rid of this prior to tiling, use a piece of wood and run it upwards unce you have rapid set on the wall, abit like browning if u no what i mean?....this way it will be perfectly flat :)
Goods news, thanks Gents.
Now, if I go over the walls and find deeper depressions than 1/4" what would be the limits if this solution?
macten
1,158
Nottingham
Cement board means their won't be a weight issue so you can go quite thick - not all in one hit mind, just build it up over a few layers giving previous layer time to go off.
Obviously if you find it's out by miles over a large area then bite the bullet and sort out the rogue stud.
Which ever way you go be sure to get it flat before you start tiling unless you're a sadist!
Reply to Tub surround problems in the UK Tiling Forum area at TilersForums.com
I am installing Hardie backerboard for a bathtub surround and plan to tile the tub surround with...
Jpvvpj
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
Tilers Forums on FB
