Two way light swithch with 2 cores! Discussion ThreadTwo way light swithch with 2 cores! Electrical Advice
So i have a Ceiling Fan (lets just class it as a Light with a Pull cord at the light) and a light switch
Problem is i turn the light off at the Light at night .. and when i wake up i turn it on at the light switch.
Sadly the light switch is TWO Core so it doesnt really effect the light , ONE switch is on then the light is on, and other light switch will not turn off
So thinking of a Relay to change the 1P2T on-off switch in to a 1P2T on-on, not sure on what relay to use if i would have to drop the voltage down (making it even more complex) to send a signal to the relay via the LIGHT SWITCH.
also not looked in to the Light Switch at the Ceiling, just hope its a 1P2T on-on
Sorry for the Relay switch icon best i could do on this APP
Two way light swithch with 2 cores! for the original thread on Electricians Forums
