Mark Parmley
So I'm tiling my entire bathroom for the first time. Walls are all prepped and I'm just trying to get my head around setting out.
The problem I'm having is that I've two windows of different width and height, on the same wall. They're also positioned about 6 inch from the corners of the room. This means that no matter which way I plan my tiles out, I end up with small cuts at either end and/or around the windows.
Am I missing a trick to make this work? Or if its inevitable, from your experience where is it easier on the eye to have the smaller cuts?
For info the tiles are 600x300 and being laid in a stretcher bond pattern.
