Typing wooden bathroom floor help please
Boogi
Hi all, I'm new here so look after me please:smilewinkgrin:
I am in the process of re-doing my bathroom, and I have a number of tile related questions, some wall some floor, before I ask them let me tell you my plan and you may be able to offer some advice, I plan to remove everything out of the bathroom, including all fittings tiles , skirting, I also intend to remove the ply flooring that has been down for twenty years, I then plan to add extra noggins in between the joists, the put new 22mm waterproof ply down , seal it, then tile over it, Then put the bath in and chop it into the wall (it only just fits long ways) then get the room re plastered, then tile down to the new floor and also down to the bath edge so I don't have to use those horrible plastic things, I also intend to tile up to the window edge on the wall, then overlap that with the window sill tile, so I can avoid using the other plastic finishers. . So questions
1. Am I doing the right thing by ripping the floor up and fitting the noggins in
2. How thick should the ply boards be and is ply alone sufficient, what I don't want is a massive lip from the bathroom to the hall
3. What sealer do I use
4. What adhesive is recomended
5. So many tiles, ceramic, slate, quartz...... What I really want is a sparkly tile like galaxy, but I am told that natural stone will brake.
6. Toilet pan? Is it ok to sit on the tiles or tile round it
7. Am I doing the right thing chopping the bath into the wall
8 am I doing right with my window finish
Thanks in advance if anybody has the time to answer
