SwitchUK
Hey guys,
First of all; Great forum. Have been reading for a while when i've been researching UFH and everybody seems really friendly (even to lay people like myself) so I thought I would ask all my questions in a single thread before placing my orders.
The room is a bathroom. Its on the second floor (like most are right ) with 1 external wall, 1 party wall and 2 internal walls (made of the worst type of 1900 breeze blocks). The room Dimensions are only quite small: 2100x1900 but the ceiling is quite high at 2600. Ive calculated the volume of the room to be about 10.4m3 although I didn't exclude for fixings.
The floor area excluding the bath (but including the tiny volume taken by the pedestal sink and toilet) is about 2.68m2. There is a radiator in the room at the moment (that I am hoping to get rid of) its a K2 600x800.
Question 1: If the floor space is only 2.68m2 can I eUFH as a primary heat source for the room?
Because this is a bathroom space I need to keep the thermostat outside the room (I'm told electricity and water don't mix :lol but it seems that all of thermostats on the market with air temperature sensors are built in to the unit and therefore would be inaccurate if kept outside the room
Question 2: Is there anyway around this? Can somebody recommend a thermostat with external air temperature sensor and floor sensor?
As you can imagine with a 1900s stone built terrace house the floor is made of ton and groove floor boards. These obviously flex a small amount when you walk on them so I would be looking to ply out the room with 5-6mm ply. Follow that with a 2mm layer of flexible adhesive before laying an insulating layer normally about 6mm. Follow that with 6mm of flexible tile adhesive with the heating element and floor sensor internal to it and a 6 or 8mm floor tile. This means that the rise from outside the door to inside the door would be 6+2+6+6+8 = 28mm. If the floor was carpeted on the other side the rise would be nothing like 28mm. I'm Worried its gonna look crap when its done because the door opens internally and would have to be cut to accommodate the step. You would then see the step from the outside before even entering the room . Plus this creates a trip hazard .
Question 3: How do I make a 28mm rise look good? and less of a trip hazard?
That's about all I can think about for now, If I can think of anything else then I will of course let you all know.
Many thanks
SwitchUK
Many thanks
SwitchUK
