Discuss UFH Heating Sensor Help in the British & UK Tiling Forum area at TilersForums.com.
siremastimus
Hi
I've bought a pack of UFH from uheat as recommended on here. I have taken up the old floor boards, reinforced the joists with noggins and plan to lay 18mm WBP plywood where the boards once were. On top of this I plan to put down 6mm Marmox boards on some Mapei Kerraquick and then some SLC on top before finally laying the tiles in flexible adhesive, my question is that with the senor conduit being about 16mm thick can I take a 10mm channel out of the WBP ply with a router and then lay the 6mm marmox boards either side of the protruding conduit the sensor is in before covering in SLC if that makes sense!
Stewart
I don't use the conduit, I just install a spare sensor and slc over the top of it. You better check with your mat supplier to make sure this is ok, but it was given the ok by mine.
Created on iPhone.....
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
It creates a weak spot that's the problem. Although it's only 25% of the thickness you'd intend on taking out, it'll make that area a lot weaker than the rest. If you do need to do it, don't cut a v-type shape in it, do a sort of half circle which would be much stronger. (If you have a router bit that sort of shape).
I'd even consider cutting a shape into the back of the tile(s) that needs to sit on that area moreso than the substrate. I've done this before by placing the tile on top of a wet cutter that has no guard on it. Quite dangerous to be honest but if you take you time considering it'll just be one or two tiles it can be done.
If you have time and can plan it, take 3mm out of the board and whatever you need to out of the back of the tile, and sort of do a bit of both.
U
Uheat - Keith
A good system would be the 12mm Conduit in 6mm SLC & 6mm Marmox board.
That way, not cutting into the 18mm ply.
Conduit is 12mm, to allow approx 8mm sensor end, wire about 5mm.
Make sure sensor at end of wire is approximately 35 – 40mm from any heating element, if it is in the conduit or if outside the conduit.
The conduit is so the floor sensor can be removed in years to come if you wish to replace Controller for different model.
Warm regards,
Reply to UFH Heating Sensor Help in the British & UK Tiling Forum area at TilersForums.com
I’m nearly there with a bathroom tiling Project and managed to make it this far before getting...
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
