Discuss ufh, low profile before a floating floor gets put in in the Canada Tile Advice area at TilersForums.com.
Ttt1601
went to have look at nice big job yesterday, standard story, couple just got the first builder they could in, hitting the final stages and now the problems and cost is going up, but the new extention is all alpha hemi hydrate screed with wet ufh so now real issues there hopefully, its the exsisting house that causes the issue, builder was planning on 25mm celotex with 25mm insulation board with wet ufh pipes in on top then green chipboard over that, through the whole house including the wetroom, and of course the tiler can tile it!!!! hasnt been fitted yet, but they have paid for the chip board
i want the whole area and am trying to come up with the most cost effective way to get me a good surface to work on, height is limited as it has to all flow through from extention, they are set on the wet ufh system in one form or another, basically got 25mm + 25mm + 18mm so 68mm total to play with. best ideas gents???
J Sid
ok, done this a few times
30mm blue insulation board
20mm low profile insulation board with 18mm pipes set in
Ditra
Tiles
first layer can be any thickness depending on final height needed.
this is now a solid floor, not floating so tiling is safe
Ttt1601
Cheers Julian, just so I'm getting this correct, it's blue insulation board ( backer board Yes?) Glued to existing Floor with the insulation board for pipes glued to that the ditra straight on top. Correct Yes? Sorry mate just want to have it clear on my head before I speak to customer.
If needed to level Floor a bit could that be done just before the ditra or right on the bottom? As this is going on the existing Floor slab of the old house so prob not the flattest or most level to begin with
J Sid
clean, prime and level slab/beam and block.
prime blue insulation boards and glue down to sub floor.
prime top of stuck boards
dry lay boards with cut outs to make sure the pipes runs are correct, this needs a lot of planing in a multi room situation. Board supplier my do a drawing!
prime under side of boards with pipe cut out board and glue down
fit pipes
prime surface
glue Ditra
tile
the first layer of boards needs to right thickness to get the right ff height
@Uheat - Jake suppliers these
if he can't help pm me and I will help more
Uheat - Jake
TF Official Sponsor
143
743
Can offer two solutions for that type of height, the first would be as Julian has mentioned, a 30mm Insulation board with then a 18mm Retrofix panel on top creating a solid floor for tiling on to or even a skim of SLC first before tiling.
We can also offer a 50mm XPS retrofit panel which is a 50mm standard insulation board but with pipe channels grooved in for a 16mm pipe, this system would need a 18mm ply over the top of the panel which would create a floating floor instead.
Feel free to give me a call if you'd like any information on the systems which may help when explaining to your customer.
Uheat - Jake
TF Official Sponsor
143
743
we don't like the f word on here Jake, please refrain from using it :)
Free? Nothing wrong with that, can offer a free installation kit on trade orders ;)
Edit: Just noticed you meant floating :D
Reply to ufh, low profile before a floating floor gets put in in the Canada Tile Advice area at TilersForums.com
Hi Ive been browsing your forums over the years looking for guidance for odd tiling DIY tasks...
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
Hi - we're renovating a house in Norfolk at the mo. I am getting conflicting advice from the...
5K
Ttt1601
Abbotts Ann, Hampshire
Website
https://www.facebook.com/t.thompson.tiling/
Business Name
T T tiling
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
