Discuss UFH mat in bathroom Electrical Advice in the Electrical Advice area at TilersForums.com.
UFH mat in bathroom Discussion ThreadUFH mat in bathroom Electrical Advice
Was at a job yesterday & whilst running cables for lighting in a side attic space I came across something I’ve not see before (not surprisingly). The couple had a new bathroom installed last year & by the looks of it whoever installed the underfloor heat mat, they never measured the UFH mat correctly for the size of the bathroom. So from what I can see what they’ve done is when they got to the last tiled part of floor they’ve drilled a hole in the floor & stuck the heat mat wire under the floor & run the heat wire free in the void for about 300mm into the attic space & then have fitted a thick length of ply to joists, ran the excess cable out on top of the ply & then fitted another bit of ply on top of this. Doesn’t seem safe to me, should I notify the customer? I’ve been reading heat mat cable in air is a no no.
UFH mat in bathroom for the original thread on Electricians Forums
Reply to UFH mat in bathroom Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
