Discuss ufh mat over 25mm ply. Need insulation boards? in the Australia Tiling Forum area at TilersForums.com.
Stef
Same as Doug above.
6mm Marmox insulation boards before 160w/m2 mat.
As called construction boards.
Always powdered flexible tile adhesive - powdered flexible self leveling compounds.
Warm regards,
I've a job to price up Keith,
It's on a concrete floor & the client wants ufh but I've got a height restriction of 20mm.
Can you tell me the difference between running cost wise of a job with 10mm insulation boards v a job with ufh straight onto a concrete slab?
U
Uheat - Keith
Good morning Stef,
Never seen any official report on this.
With boards any system will be approx 90% to 100% good.
Without board, this will only be approx 85% to 95%.
So many other things in the mix. Internal and external walls, ceilings, windows and doors all come into it.
The main thing is, the better the insulation, if you can use it, the better the system will work.
Hope that is of a little help.
Warm regards, Keith
Reply to ufh mat over 25mm ply. Need insulation boards? in the Australia Tiling Forum area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
I'm a total tiling beginner having my kitchen/diner redone by builders. The dining area has a...
23K
Deleted member 57709
Hi, This is for a bathroom (including a bath). I have a buildup of timber joists / 22mm ply /...
Hello, I’m just having some work done in my house and decided to go with underfloor heating...
Tilers Forums on FB
