Hi guys,
I am after some advice from the pros, so figured id ask here.
in my new extension I have has a wet ufh system installed under some liquid screed (gyvlon evo I believe)
Its been down for over a month now at the depth of approx 50mm.
I am now ready for tiling so have been reading up on the prep (which I didn't realise it needed)
Ive been told that I should have sanded the surface after a few days to remove some of the surface dust etc.
then I need to prime the lot before I can lay porcelain tiles.
so my questions are:
What is my best option for sanding?
Whats the best primer?
What adhesive should be used? (As cement and this type of screed don't suit each other)
And finally, how can I tell for sure that the screed is ready (moisture reading)
I am aware of the 1mm a day but I want to be sure.
I hope you can help me out. I like to know what I am on about before I get a tiler in.
Many thanks in advance
Coops
Coops
