Rich
Evening all, thought I would put up a little bit of info on the Ultra range of powder adhesives for anyone who may find it useful.
Ultra ProSet SS - Standard Set Tile Adhesive
Ultra ProRapid RS - Rapid Setting Porcelain Tile Adhesive
Technical Support - 01827 871 871
- Suitable for walls and floors
- Bed Thickness - 3-12mm
- Open Time - 1 hour
- Set Time - 24 hours
- Conforms to EN12004 class C1ET
- White/grey
- Frost resistant
- Gypsum plaster (Primed)
- Gypsum plaster board (primed)
- Concrete render
- Brick work/block work
- Fixed Plywood (primed)
- Cement Screed/Leveling compound
- Concrete sub-base
- Ceramic/stone/terrazzo
- Underfloor heating (Mix with Ultra Prime IT FP additive as Directed on packaging)
- Fixed Marine ply (Mix with Ultra Prime IT FP additive as directed on packaging)
- Fixed plywood (Mix with Ultra Prime IT FP additive as directed on packaging)
- White/grey
- Bed thickness 3-12mm
- Open time - 20mins
- Set time - 2-3hours
- Conforms to EN12004 class C1FT
- GreyCeramis and mosaic tiles
- Internal & external
- Frost resistant
- Gypsum plaster (primed)
- Concrete render
- Brickwork/block work
- Fixed plywood (primed)
- Cement screed/levelling compound
- Concrete sub-base
- Under floor heating
- Ceramic/ stone/terrazzo
- Fixed marine plywood (Mix with Ultra Prime IT FP additive as directed on packaging)
- Bed thickness - 3-12mm
- Set time - 2hours
- Conforms to EN12004 class C2FT
- White/greyImproved flexability
- Porcelain and natural stone
- Frost resistant
- Concete render
- Brick/block work
- Concrete screed/leveling compound
- Ceramic/stone/terrazzo (Mix with Ultra Prime IT FP as directed on packaging)
- Fixed marine plywood (Mix with Ultra IT FP as directed on packaging/Telephone for technical support)
- Bed thickness - 3-20mm
- Conforms to EN12004 class C2FT S1
- White/greyInternal & external
- Frost Resistant
- Concrete render
- Concrete sub-base
- Open time - 1hour
- Set time - 16hours
- Conformes to EN12004 class C2ET S1
- White/grey
- Internal & External
- Frost resistant
- Porcalain and natural stone
- Concret render
- Brick work/ block work
- Concrete sub-base
- Fixed marine ply
- Bed thickness 2-20mm
- Open time - 30mins
- Set time - 5hours
- Conforms to EN12004 class C1F S2
- Dark grey
- Water proof
- External & internal
- Concrete rended
- Concrete sub-base
- Fixed marine ply
