Discuss underfloor heating in kitchen. in the UK Tiling Forum area at TilersForums.com.
jwatson
The sub-floor is concrete throughout the whole ground floor. and is tiled with ceramic 300's. It is to be the primary heat source in the kitchen, so may go for a higher wattage??. we currently have a radiator but it is in the way really, we plan to take it out and replace that part of the kitchen with more units.
sorry electrical underfloor heating poss 200w?? not really sure.
last winter was quite cold in this house. asume the concrete conducts the cold right through.
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
I'd go for the 200W and also a thick layer of insulation.
If it was cold, I'd also consider keeping the rad until you've done a winter to see if you can cope with removing it just to be sure. Especially as it's your own kitchen and not a customers you'd need to go back to etc.
U
Uheat - Keith
Underfloor heating at 200w/m2 is from our Conservatory range, but good to also use in Kitchens as you will lose some floor space to the Kitchen units.
Will be full heating (primary heat), depending upon the heating coverage of the total gross area, how well the dwelling is insulated and the heat loss figure for your gross area.
As over, 10mm insulation in the floor also.
The Heat loss figure for your area is about how each surface loses the heat: Floor surface, internal walls, external walls, doors and ceiling.
Very long winded calculation, but in general 200w/m2 is good for any Conservatory, so will be good for a Kitchen.
Warm regards, Keith.
Reply to underfloor heating in kitchen. in the UK Tiling Forum area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
