Discuss underfloor heating in the Canada Tile Advice area at TilersForums.com.
MRM Tiling
Hi i have a job coming up and need some advice, it is on a concrete floor which is at least a year old and has pipe heating underneath it which has been commisioned and the screed conditioned. can i tile straight to the concrete with flexi adhesive or do i need a decoupling membrane down? also what is advised for after the tiles are laid so i can tell the customer. and one more thing can i tile from one room straight through to another or have an expansion joint where the doorframe is? need advice as i want to get it right
mattle40
sorry i think they are seperate, as in you can control which area is heated in the house and also it was tested up to full heat getting there in 5 degree intervals and was switched off 2 weeks ago
I would put expansion joints in the doorways if the rooms are heated seperately,
I would imagine this would push ditra to its limits and i wouldn't be comfortable with the install my self
Eager to hear other opinions myself to be honest.
jimthetiler
Hi
I presume you are laying the matting on a screeded floor.
expansion joints at doorways is good.
check screed is laid in one go,if the screed has been laid in different stages you will need to decouple where the join is,ask the customer if uncertain.
once mat or wire has been laid it will need testing,an easy test is to wire a plug on each matting and plug into the wall socket,this is safe up to 10mins but you will only need a couple of mins to know the its all working.
now you should use a latex based self leveling compound and cover the wires.
when dry do another plug in test then you can tile using flexi
philipb
Worked on a new build recently,120 mts of limestone on wet ufh,tile supplier was pushing
a new adhesive from Granfix that goes down with no need to decouple.They
supplied a procedure which was done as they advised and its been down since
december with no sign of any problems.Granfix tech will advise on its use.
Saved a lot of money.
White Room
Does that include natural stone tiles....
philipb
Yes it does,they even said not to bother with expansion joints,they even
guarantee the job and advise that pics are taken at every stage so they can
check it in the event of a problem.They even send a rep if you want!
I was a bit worried but didn't need to be,job is spot on.Floor temp has been as
high as 50 deg c.
Reply to underfloor heating in the Canada Tile Advice area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
underfloor heating
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
