Discuss underfloor heating. in the Australia Tiling Forum area at TilersForums.com.
Rancot
Hi. I am a keen DIY enthusiast over many years. Came to this site when researching UFH. One job I did not enjoy previously was using self levelling compound - it did not level! maybe too thick? However as I am thinking of laying UFH loose cable I will need to use it so any tips would be appreciated. Also, has anyone ever recommended using al. foil under 6mm insulation board to increase the insulation but keeping low height of thickness? Would this be dangerous and make the wire overheat etc?? would be working on concrete base.
AliGage
Subscribed
4,531
1,188
Peterborough, England
p4ulo
some companies will sell you a paint-on solution that "improves" insulation properties. maybe try that under 6mm boards?
I used 10mm in the end, and I was worried about height, there are gains over 6mm, but if you are really conscious on it, go for 6mm, I'm sure it'll be fine.
Someone used a different SLC on a thread the other day, and it mixed watery and was very easy to level.....Gimme a minute I'll add the name....
ITS UZIN.....do some research.....might be able to find some at a decent price near you? Good luck - pictures please!
Rancot
Thanks your points have made me give more focus to movement.
Rancot
Thanks - saw this and it looks to be good
Q
Qwerty
I will now give my opinion on your situation...... Forget the foil idea straight away! Prime the floor with an acrylic primer and fix 10mm insulation boards using bagged cement tile adhesive. An easy, recommended and trouble free installation. Sorted!
As for SLC, any quality fibre reinforced bagged SLC poured evenly over the floor and floated carefully will leave a level smooth finish
Chalker
1,058
Tadcaster
The foil won't be much help as it reflects light. Underfloor heating works initially through conduction, from the wire/pipe into the finish layer. This then emits heat through transfer to air and a little light wave energy.
Therefore to get the most heat into the room, You need a good dense mass above the element, this will give better heat transfer to the room and the thicker the insulation mass under the element, it will loose less heat downwards.
Sorry for going all technical!
Rancot
Thanks. This is what I want to do - however it will take this floor above the adjacent floor which is sculptured porcelain tiles. These really could do with covering as the floor is the result of 3 different room extensions. What is the best way of covering these tiles, I thought of vinyl over hardboard or thin ply as I cant go direct on to the tiles because of the ridges in their pattern. Or should I just self level again? This job is getting like pinoccios nose!
Rancot
Thank you for taking the time to reply - interesting
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
Welcome to the forum. :)
Yeah as above. SLC is more of a push it around and it'll sort its self out kinda stuff.
Reply to underfloor heating. in the Australia Tiling Forum area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
underfloor heating.
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
