Discuss Uneven tiles wall in the Canada Tile Advice area at TilersForums.com.
Tile Shop
Between two tiles, no more than 1mm for grout joints less than or equal to 6mm, 2mm for joints over 6mm wide.
Then, anywhere on the walls, with a 2 metre straight edge with 3mm feet at each end, no peak in the tiling should impede the straight edge at any point, and no gap between the base of the straight edge and the tiles should exceed 6mm. Basically +/- 3mm over any 2 metre length.
It is in bs5385 part one. But i don't have my copy to hand. I can read over it in the morning and let you where it is. Its also exactly the same rule for floors.
Tile Shop
Found it. Section 7.1.9 - Tolerances:
7.1.9.1 Finished tile Surfaces
The surface should be true such that, when checked with a 2 m straightedge with 3 mm thick feet at each end, the straightedge should not be obstructed by the tiles and no gap should be greater than 6 mm.
There are permissible manufacturing tolerances for ceramic tiles defined in BS EN 14411; certain types of tiles, e.g. extruded or large format, might have permissible surface flatness irregularities that cannot satisfactorily be accommodated within the surface flatness tolerance permitted to the tile installer; this should be taken into account when evaluating the achievable flatness of a wall tiling installation.
NOTE - Where adhesives are used, this degree of accuracy can be achieved only when the background surface is equally true.
7.1.9.2 Across joints
There should be no appreciable difference in level across joints (commonly called "lipping") and the maximum deviation between the tile surfaces either side of the joint, including movement joints should be as follows.
a) Joints less than 6 mm wide, 1 mm.
b) Joints 6 mm or more wide, 2 mm.
Reply to Uneven tiles wall in the Canada Tile Advice area at TilersForums.com
Hello, I'm having trouble finding any decent stockists locally. I've got a Topps very near, plus...
Hi, I have an issue here. My tiler has left a gap between the trim and the wall. No doubt the...
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
Uneven tiles wall
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
