Discuss Use of PVA on floor in the British & UK Tiling Forum area at TilersForums.com.
CDS
If I'm being honest 4mm ply isn't really thick enough -sorry! You should be looking for a minimum 12mm-18mm on floors. As with previous post do not use PVA.
Use cement based adhesive and follow the bags fitting instructions. They usually recommend priming joints and edges of boards. But this depends on the adhesive used.
DHTiling
4mm ply is not suitable enough....not just the thickness but not moisture stable either...
You could use 6mm hardi backer cement type boards if your floor is solid enough( little deflection)...this will give a better base to tile too and keep the height down..
Mapei say you can use thier adhesives with hardibacker...
CBTC
Yes, quite right Dave. On a broader note its interesting how often after the requirement for correct thickness of board is stated and explained in a discussion about a floor, that it all gets lost and the must word comes up regarding not raising higher than 'x' level - as though the strength requirement is an option. Even with builders sometimes.
Reply to Use of PVA on floor in the British & UK Tiling Forum area at TilersForums.com
  • Question
I’m looking for approx 25m2 of a porcelain floor tile - style name Southrop Natural, which has...
Hi - I'm laying hardiebacker on top of green chipboard. I have a load of Mapei Primer G left...
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
Use of PVA on floor
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
