Max_Antax
Dear all,
I have corner shower which is leaking, I believe, because of faulty grouting.
One of the walls has some movement and this results in the grout failing at regular intervals: I have re-grouted two times now and the problem stops temporarily, only to for it to come back after 3 / months.
As I'm planning to undertake major refurbishment soon I'm looking for a quick fix and was wondering: can I use Silicon instead of grout to fill the tile joints?
I'm planning to rake out the grout, mask the tiles and fill the joints with Silicon. I would say that it should be sufficient to do this up to 1m from the tray. I'm planning to use low modulus exterior grade Silicon of the type used to fill expansion joints.
Is this idea any good? Any specific product in mind? Can you think of suitable alternatives?
Many thanks for your help,
Max
Max
