Discuss using ardex 7001 in the UK Tiling Forum area at TilersForums.com.
robjoe90
im trying ardex 7001 for the 1st time , any advice ? its a bathroom floor , ive boarded it out with ply , should i use a primer ? its ceramic tiles , i usually use bal acrylic primer apd but thats for plasterboard and cement .
the ardex bag recommends ardex p51 primer but my supplier doesnt have it , anything else similar i could use ?
grumpygrouter
Yes you will need to prime your boards. P51 is what your should use but I imagine that BAL Bond SBR will do fine as it is used for very similar things in addition to priming, using in a slurry coat for instance.
Make sure when you mix it, it is quite a thin mix, this helps to give a solid bed fixing without back buttering. Need to work quite quick as it is a rapid set though should have a bucket life of about an hour.
Grumpy
Reply to using ardex 7001 in the UK Tiling Forum area at TilersForums.com
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
Hi everybody, I've taken on the task of tiling my own kitchen, and before I wreck everything and...
Hi, a long time since I have been here but back for some advice/reassurance ! About to tile my...
using ardex 7001
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
