DHTiling
maybe Alan jackson can shed some light on this....
So if using a gypsum adhesive onto an un primed or primed as this one was then can the moisture from the adhesive going into the substrate rise and then soften gypsum adhesive back up and knack them...
We know that gypsum does not like water to a certain degree but quite worrying to read this... some members might know where that info quoted came from , hence why i posted it here just to getting Alan's feedback or anyone who has an answer..
it is to be noted that some gypsum adhesives say not to prime , so if this moisture can migrate back into the adhesive bed and then cause it to soften then what bloody good is it.?
600 x 600, 600 x 300 and 300 x 300 Brazilian Black slate floor tiles laid with Nicobond Gypfix
adhesive onto a Bardon High Flow calcium sulfate pumped screed with underfloor heating
were reported to be hollow on corners. Screed had been tested and found to be dry before
tiling and brushed and primed with an acrylic primer.
Corner hollowness was confirmed on the larger sized tiles. Where bedding was exposed
following removal of a hollow tile earlier, adhesive residue to the screed was hard, dry and
well adhered. Another 600 x 600 hollow tile still in position was re-lifted. Exposed adhesive
was darker in colour and gave moderately damp readings when tested with a Tramex
moisture meter. The adhesive was not as hard as previously found, especially near the
centre of the tile. A further still installed tile was then removed. Adhesive was both damp
and soft. Tramex reading was High confirming the dampness.
It was concluded from a detailed record of dates and actions that the screed was dry on tile
installation. Moisture from the original application of adhesive had probably been absorbed
into the dry unheated screed sufficient to allow setting and hardening. However when
heating was switched on, no matter how gradually, this moisture was driven back up into the
adhesive, causing it to soften or revert and loose adhesion. The impervious nature of the tile
and the small number of joints meant there was little escape to atmosphere but the areas
around the corners became hollow and dry and suffered most from floor heating stresses
whilst adhesive in the centre of the tile became wet and stayed wet. Further tiles will need
removing to thoroughly dry the calcium screed still affected by moisture and then re-tile
using an adhesive less susceptible to damp.
