Discuss Using manual transfer switch to distribute power Electrical Advice in the Electrical Advice area at TilersForums.com.
Using manual transfer switch to distribute power Discussion ThreadUsing manual transfer switch to distribute power Electrical Advice
The application is providing AC to a camper. The goal is to provide AC input to charge a solar 'generator' when the camper is connected to shore power. Then, when the camper is disconnected from shore power the transfer switch is moved to Position #2 for the solar generator to provide AC power to the camper. To accomplish this goal I tap into the camper's existing distribution panel bus bars.
  1. When the manual transfer switch is in position #1
    a. Shore power is routed to a Jackery solar generator. The Jackery is limited to a 15 amp AC input, which is the reason for the breaker.
    b. AC output from the Jackery is disconnected.
    Note: AC output from the Jackery is off by default. A button on the unit must be pressed to turn on AC output.
  2. When the manual transfer switch is in position #2
    a. AC input to the Jackery is disconnected.
    b. Power is routed to the camper's distribution panel from the Jackery's AC output.
    Note: The circuit breaker is needed here, but I provided it as an additional cutoff.
  3. When the manual transfer switch is in position #0
    a. The Jackery is isolated from the circuit.
  4. Note: There are positions still available on the transfer switch. I intend to use a couple in Position #2 for some DC distribution that is completely isolated from the AC distribution.
Is this wiring correct? If not, what corrections do I need to make?
Thank you,
Andrew
[ElectriciansForums.net] Using manual transfer switch to distribute power
Using manual transfer switch to distribute power for the original thread on Electricians Forums
Reply to Using manual transfer switch to distribute power Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
