Discuss Using Self Levelling Compound with UFH mats in the UK Tiling Forum area at TilersForums.com.
ap222
Hello all, I'm just about to lay my first Devimat UFH. The substrates are 18mm floor boards, 12mm ply (all screwed down at 300mm) & 10mm Marmox insulation boards on bathroom floor.
The floor is completely flat & level. Do I still need to use a slc, as the devi instructions say tile straight over with a flexible adhesive.
Reading from other posts, I gather its to protect the wire from damage.
I'm planning to use Mapei Fibreplan, and do I also use the slc over the wet dec in the wet area? I'm guessing not as it may mess up the gradient?
regards
Richard Edwards
Hello ap
Definately better to use latex based SLC on top of the UFH Cables - cover them to a flat surface - important to use SLC with latex / highly flexible alernative / mapei fibre plan might ok you'll have to check this out with Mapei or most of the boys and girls on here that use Mapei.
As for the Wet area - deck etc - never lay UFH cable on wet room decks and never apply SLC or anything else for that matter - subject to the type of deck you have. If its a cementous board deck with pre-manufactured fall, don't ever, and the only thing I would consider on a 'solid plastic deck' would be a thin brushed-on sbr primer coat, although this should not be necessary - These decks are all designed to accept tiles / flexible adhesive directly :thumbsup:
ap222
Thank you for the advice guys, I will use the slc to cover the cable.
Richard, I'm using the novellini Linear Wet dec with a 2 way fall & was hoping to install the UHF onto the deck. The instructions advice placing any UFH atleast 20cm away from the trap to prevent water in the trap drying out.
The tray is white looks cementious and has a preformed 2 way gradient.
regards
Y
Yorkshire Tiling Services
Apart from above mentioned the other main reason to self level over UFH cables & mats is to avoid creating hot spots.
Hot spots occur when there are air pockets in the adhesive,when used directly over cable or mat.
The cable should be ennitrely covered ( encased )! This is very difficult to do unless self levelled. The hot spots are areas where cable could malfunction or over heat.
ap222
I dont know much about the tilesafe membrain as i'v ever used it, i have heard that its a ***** to install, if your not used to it though. Me personally would not have the uhf on the deck if not covered with a membrain.
Well, i've bought it now so got no choice but to go with it! I'm sure I'LL be alright as long as I work methodically & not rush the job:thumbsup:
Thanks for your input guys, much appreciated.
Y
Tilesafe membrabe is ok to fit if you follow instructions.
Make sure you do not remove protective film prior to tiling,it is so sticky you will get stuck to it. It will also attract & stick every bit of dust & rubbish that is around.
Also, very important to press and roll out as instructed, otherwise you will get air bubbles in the membrane. These can be an absolute **** especially if fixing mosaic tiles.
Make sure you seal all membrane joints with supplied sealant, do not use Silicon as this destroys the membrane & invalidates any warranty.
Use supplied primer as directed prior to fixing, all areas should be clean & dry prior to priming. Primer should have been allowed to dry out prior to fixing membrane.
Richard Edwards
Hi ap
Well some members say its ok to install UFH on the deck and I still say not - pick the bones out of that if u will. Personally I would never do it, apart from the fact that I cannot see a technical / comfort reason to do it and you are spending money on an extra area of matt apart from the increase worry of interferring with the falls - ie from outer to inner on a Lux Cementous Deck its 50mm - 35mm ie the fall is only 15mmm over say 900mm on the largest deck, enough to drain OK but not much to play with if your adding other components before tiling.
As regards the novellini Linear Wet - I cannot comment as its not a system I use, but clearly the manfacturers instructions are gospel.
Good luck with it - perhaps post a couple of 'in process ' pics if you can - I would like to see how this deck system compares :smilewinkgrin:
ap222
Hi Richard, Thank you for the reply. If I decide not to fit it under the dec
I will end up with extra UFH cable, as when I bought it, I accounted for the wet dec. :mad2:The kit may be slightly larger for the room now.
Can I just run the excess red cable along the perimeter of the room, keeping 50mm gap from other wires to prevent overheating?
I will get some pics up of the install as soon I get down to fitting it.
I think this dec is made by Impey (Linear -flo dec) for Novellini, as its resin filled and allows upto 3 traps to be fitted.
Many thanks also to Yorkshire tiler, for the advice & tips on laying tilesafe.
Y
Hello ap
There are UFH cables that are suitable for wet floors.
This is the only instace where I would not self level prior to tiling. Instead I would screed over carefully with a flat trowel, following the fall in all directions. Have done this on numerous types of wet floor without a problem or call back. Ok providing a suitable adhesive is used.
ap222
Thanks Yorkshire T, appreciate the photos you've put up, great finish on that job:thumbsup:
I checked the specs with Devimat & its totally waterproof including the cold tail. Im gonna be using Mapei keraquick flexible rapid set adhesive for the tiles so it should be fine.
Just a curious question, why isn't it wise to use slc on the decs? Is it because it would not maintain the preformed fall of dec an try & set horizontally?
regards
Y
regards
That is correct :thumbsup:
Reply to Using Self Levelling Compound with UFH mats in the UK Tiling Forum area at TilersForums.com
I’m nearly there with a bathroom tiling Project and managed to make it this far before getting...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
