Guest viewing is limited
Discuss using the right size levelling clips in the America Tile Forum / Advice Board area at TilersForums.com.
Hi guys ,
I'm new to this forum and I haven't done a lot of tiling so would like to get some advice on choosing the correct size levelling clips ( clip and wedge system ) . I'm doing an external patio on a concrete slab and want to end up with a 3mm grout line for 45cm square porcelain tiles . When I use the 3mm clips and tighten them , the joints seem to pull apart slightly . I've got round this so far by tapping the tiles back together with a block of wood and rubber mallet but this takes extra time and can disturb other joints . Would I be better off using narrower clips in conjunction with regular spacers .
I guess what I'm getting at is would it matter if the clips 1.5 or 2mm are "loose" in the joints if I use 3mm spacers aswell ? ............. Thanks all
Hi guys ,
I would suggest using 2mm clips for the tiles. You also need to use wedges between tiles and walls. Otherwise, the grout joints will be moving. Let me know if you want some advice
Thanks mate , I've given it a go with 1.5mm clips and 3mm and it seems to work better . I have used some of the levelling wedges where I've left off for the day to stop tiles dropping . Yea , hadn't thought about the edges yet , but I'll follow your advice when I start cutting .
Reply to using the right size levelling clips in the America Tile Forum / Advice Board area at TilersForums.com
Hi first timer to tile, im getting all my prep work and tools. My question is will the self...
Can I trouble some experts in here for some advice on laying pavers on a concrete pool surround...
Hi guys, had some great advice here before so thought I would ask here for advice again...
USA Tile Forum Popular
America Tile Advice Trending
Australia
What member type are you?
  1. Homeowner
  2. DIY Wall and Floor Tiler
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
