Discuss Using Weber powder adhesive for first time. in the UK Tiling Forum area at TilersForums.com.
joshtiler
Hi all, i have been reading this forum for weeks now and have learnt alot of things i was not taught. I get the impression that most of you are not fans of tubbed adhesives unless used for kitchens and tiles under 300x300 (and sometimes not even for them), i have read up on the benifits of cement based adhesives and have decided to make a permanent swap to powder adhesives. My local CTD are doing 20kg bags of Weber thick bed white adhesive for £12.99 and so i have grabbed some the job im doing now.
The walls are nearly all plaster apart from one small section which has been left bare aquaboard/plasterboard and i have primed all the rest with bal SBR but am wondering does the aquaboard/plasterboard need priming also? Is bal SBR suitable for the job?
Also is the Weber adhesive a good adhesive in your opinion? is it more difficult to use because of pot life being shorter that tubbed stuff?
Many Thanks.
Josh
joshtiler
Thanks alot sir ramic, that was what i thort but the guy in CTD said that the cement in the adhesive might react badly with the plasterboard and so it will need to be primed. Wanted to ask someone on here for a second opinion :)
Thanks peteablard for advice, i will definately do that, i have never used powder addy on walls before so im keen to give it a go. Seems the general opinion on here is that even the expensive tubbed addy is not as good as the powdered stuff (and powdered is cheaper)
Reply to Using Weber powder adhesive for first time. in the UK Tiling Forum area at TilersForums.com
I’m halfway through tiling a shower cubicle at home. First time doing any tiling. I’ve used...
Hi guys, Hope you are all having a fantastic Xmas. To cut a long story short I have installed...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
