• Thread starter DevsAd
  • Start date
  • Replies 0
  • Views 123
Discuss Vaillant ecoTEC 824 - simplest 30kW replacement? Discussion Thread in the Plumbing Advice area at TilersForums.com.
Hi.
Looking to replace a 13-year old 824 with a new combi as its location is being moved, so seem like a good time to also replace. The new boiler needs to be more powerful - 30kW (as against 24kW?) - as the mains supply will also be upgraded.
The old 824 has actually had its pipes shifted to the new location, so ideally looking for the most direct swap possible. Plumbers back on Tuesday, so looking for the easiest boiler swap to 30kW. Any 'Vaillant' folks on here, who can point to a current model that'll slot directly in?
Cheers.
Vaillant ecoTEC 824 - simplest 30kW replacement? for the original thread on Plumbers Forums
Reply to Vaillant ecoTEC 824 - simplest 30kW replacement? Discussion Thread in the Plumbing Advice area at TilersForums.com
Plumbing Advice
Tags
None
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
