Discuss Very LARGE holes (using a hand drill) Easy? in the British & UK Tiling Forum area at TilersForums.com.
Deleted member 1779
[SIZE=+2] Fitting large items like waste pipes and fans through tiles[/SIZE]
And achieving an elegant finish. IE not a ragged hole !
Method 1: Using a hand drill
Best material to use for a template is plasterboard. (Yes really)
Score the top paper with a knife round the drill bit.
Drill will "bite" into the exposed plaster and form its own hole.
Much easier than using solid wood and a jigsaw....
Poke out circle of plaster board. Your template is done in less than a minute!
Put template onto tile. Secure in place. Stand on it. Bricks. Get a mate to hold it. Tape it. Etc
Look its working.
Remove plasterboard to reveal a neat but dusty hole is forming. Discard the guide.
Add a splash of water. Outside hosepipes are fine.
Drill slowly. Use water. Dont rush. Dont add pressure. Hole forms nicely.
DO NOT USE DRILLS TO CUT INTO CHIPBOARD - THEY WILL BLUNT - WE WERE JUST SHOWING OFF !
A sandwich of tile and chipboard .The hole is perfect. Impressed?
YOUR customers will be looking at this workmanship for many years to come.
Its a signature of the quality of your work.
And so easy to do as well. A bit of plasterboard. A bit of skill. Some time spent going slowly. And nice work as a result.
Deleted member 1779
Well the ARMEG ones at Screwfix Direct are £169.99 each.
Screwfix crowns are here
And ours are £39.99.
Armeg crowns last longer and cost more. But ours are aimed at the mid-market for those who dont need such long lasting bit of kit.
C'mon £39.99 is cheap !
Reply to Very LARGE holes (using a hand drill) Easy? in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
    • Winner
Hi All. Just been to see the Wizard of Oz @3_fall . Met Marc onsite today to pick up some...
5K
Do you need to drill holes in very hard porcelain tiles? Do you want to do it with ease, using...
Deleted member 1779
How do I drill a hole in a steel bath. Or cast iron bath. Instructions on drilling into baths...
16K
Deleted member 1779
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
