Discuss Very simple question for Professional Tilers in the British & UK Tiling Forum area at TilersForums.com.
I
ISM
Hi, I have a big project on next month and it appears that the best products around are Mapei. If anyone could answer the following I would much appreciate it, cheers.
Which primer and Mapei adhesive for tiling on WBP ply (Floor)?
Which primer and Mapei adhesive for tiling on skimmed plaster (not boards)?
I will using ceramic tiles for this project:dizzy2:
Cheers
The D
it also states in the BS5385 that The use of sheets and boards that are subject to movement from changes in moisture content, e.g.
wood-based materials such as plywood, chipboard, wood particle boards, etc. should be avoided if at all
possible.
If such boards have to be used they should be restricted to small areas and tiles should not bridge
joints between boards. It is good practice to seal all exposed edges and the backs, but not the faces, of such
boards with a suitable sealer to prevent distortion by atmospheric humidity changes. Care should be taken
to ensure such boards are not installed in a condition where their moisture content is higher than the
ambient equilibrium moisture content once the tiled installation is in use. Failure to observe this can lead
to subsequent warping and distortion of the boards with consequent cracking and delamination of the
tiling.
so you may want to think about tile backer boards.
Reply to Very simple question for Professional Tilers in the British & UK Tiling Forum area at TilersForums.com
Hi everybody, I've taken on the task of tiling my own kitchen, and before I wreck everything and...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
