Colette
Hi there,
I am new to this forum... And was just after some advise. ( I know this topic has been done to death on the internet). However there is so much conflicting advise, I'm still unsure.
Basically I wanted to restore my victorian tiles in my hall, they are in pretty good nick just a couple to replace due to cracks and a few loose. There is glue on the, which pretty much peels off so not an issue. Some cement build up by the skirting boards. But mainly just years of dirty. My questions are,
The main one is which tile restorer to use and sealer?
I have been recommended lithofin but have read mix reviews on this. I consider HG products but read poor reviews. I have read a little on aqua mix, but not sure. Other people say use brick acid or nitronox? My sister used nitronox this but it discoloured her tiles. Tile doctor seem to be recommended but not by professional tilers is there a reason for this?
Other questions I have is:
Should I clean, seal, grout, seal again a few times OR clean, grout, seal several times?
Finally,
should I use a tile colour restorer?
Which tile adhesive would you recommend?
Which grout would you recommend? Or shall I just use brick mortar as it is dark grey grout.
Any advise or tips greatly received!!!
Thanks Colette
Finally,
Thanks Colette
