Discuss Vitrex Pro 900 pump problem in the British & UK Tiling Forum area at TilersForums.com.
Musivarius
I've got a Vitrex 900 Pro bridge saw and it's worked brilliantly for me so far but i'm having a problem with the pump. There is water coming through but it only seems to be about half the amount. This started after be turning it back on in the middle of some cutting.
I've cleaned the reservior tank right out and run clean water through but it's still not flowing enough, any ideas? The saw does get a lot of use, I cut for about 3 - 4 hours at a time and the pump is removed from the tank after each session and the filter romved and cleaned.
Reply to Vitrex Pro 900 pump problem in the British & UK Tiling Forum area at TilersForums.com
Greetings All, appreciate the expertise existing in this forum. I am a home remodeler, not a...
5K
Hi everyone, I really need some pro advice as I have just had a bathroom fitted and the tiling...
Deleted member 53945
Hi. Got someone in to do the bathroom. Could anyone give me some opinions on the tiling so far...
Can anybody recommend a cutter that will produce very good edge cuts on 10mm very hard porcelain...
9K
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
