Hi all,
New bathroom Job coming up Monday. Solid walls. Old files to rip off. Walls are skim on render. Guy says render is hard as rock dimensions are tight so not got room to dot and dab. If the render stays tight what would be best prep before tanking? All work I have done for last 5 years is on PB so rip it all of replace and tank. All last solid walls I’ve done render/hard wall has been moisture damage and I’ve taken back to brick/block and started again. TIA
