Guest viewing is limited
Discuss Wall preparation for tiling in the America Tile Forum / Advice Board area at TilersForums.com.
Here is a picture of the wall on question
The paper on the face of plasterboard should be grey (or green), it looks like you have you have removed or damaged part of that top layer of paper so personally I would be reluctant to tile onto it. It might be ok but why risk it, a new sheet of board is only 9 quid.
Trigger
483
uk
The plasterboard is dot and dabbed onto the block work, would it be best to remove board and dabs then dab a new board onto the block work?
2 options-
1) Remove plasterboard and replace like for like using dot and dab method. I would also put some mechanical fixings in aswell.
2) Glue a 6mm tiling board to the existing plasterboard and mechanically fix with screws and washers through the board into the blockwork. This option is more expensive but less hassle and creates less rubbish as you don't have to dispose of the old plasterboard.
Trigger
483
uk
The board has been compromised due to the paper face being torn off unfortunately. The paper serves a couple of purposes, it has thousands of microscopic pores in it to help plaster adhere to it but it also helps to control the suction/absortion of the water in the plaster or in this case the adhesive. If you attempted to plaster that the remaining brown paper would start to bubble up and delaminate from the core. I suspect it would do the same with the tile adhesive as a result of the water content of the adhesive as it will remain wet for a number of hours. I suppose priming them and then tanking might help, but why bother, just replace them.
Reply to Wall preparation for tiling in the America Tile Forum / Advice Board area at TilersForums.com
I have recently stripped the bathroom. I have 2 walls in non water area. One wall is new...
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
Hello, I have some lovely Mexican terracotta tiles (glazed on one side only) which are meant...
USA Tile Forum Popular
America Tile Advice Trending
East sussex
What member type are you?
  1. Homeowner
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
