Discuss wall repair in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Cheers Dave,
Was looking at the one coat stuff today but wasn't confident with regards to priming (still acrylic on the bonding coat?) or setting times prior to tiling. Thats why I was going down the rapid set addy road.
Mark
Thin coats will set in no time...next day if deeper......
http://www.tilersforums.com/private.php?do=newpm&u=3
If only 3mm in depth I use drylining cement it gose off with in 20mins so shouldnt hold you up if done first.
plasterboard adhesive is gypsum based so no probs with a reaction and it dries very hard but is very porous and dusty as well so needs a couple coats of primer once dry..
charlie1
cush68,
Prime then plaster with rapid set. Then from bottom up use feather edge to get nice even wall. When pulling FE up the wall move it slightly from side to side, this will gave a better finish.
After you have plastered go back and check periodically to make sure the rapid set is not slumping/sagging , if so simply use your FE to flatten again.
Good luck:thumbsup:
Reply to wall repair in the British & UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Hi, I’ve just crossed over from the plumbers forum for some tiling advice as I’m in the process...
wall repair
    Votes: 9 5.7%
    Votes: 15 9.6%
    Votes: 11 7.0%
    Votes: 47 29.9%
    Votes: 19 12.1%
    Votes: 37 23.6%
    Votes: 4 2.5%
    Votes: 21 13.4%
    Votes: 18 11.5%
    Votes: 17 10.8%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.5%
