Discuss Wall tiles for floor tiles?????? in the Best Floor Tiles area at TilersForums.com.
maggieb
Hi, I am new here and I was so pleased to find this forum as I am in need of advice.
We are doing up a shed as a studio and where excited when we found some tiles going cheap from a place that was closing down. We purchased 60 m2 of 600x330 white tiles. On arriving home with them and looking at them closely we noticed they are wall tiles, not floor tiles. Then discovered we could not return them.:mad2:
My question is....Can we still use them as floor tiles. They have A grade on the box, no PSI stated. And if we can use them as floor tiles, what adhesive do we use. We are thinking flexi.
Can someone please advise me on what to do. The tiles are glazed with a matt finish.
Cheers, Maggie **yawn**
maggieb
If you're "doing up a shed" and it's yours for your own use, I'd use them. But only if it has a solid floor i.e concrete. Only you know how you're going to use the building and how much traffic the floor is likely to have and what sort of thing you'll be getting up to.
By the way, I'm not a tiler!
Thank you for your info...yes the floor is concrete and there wont be a lot of traffic on it. In your opinion would it be best to use a flexi adhesive or a rigid one. We were thinking of the flexi that you mix up.
Andy Allen
1,318
Gloucester
Think you should listen to the tilers...
Theres a reason why its called a wall tile.....its ment to go on the wall not the floor.
Floor tiles are graded 1to 5 grade 4 and 5 are suitable for most rooms in your house...grade 2 and 3 light traffic areas only ie bathrooms or bedrooms....I doubt your wall tiles are a grade 1 if that....infact I dont even think they grade wall tiles....still its your money so good luck..:thumbsup:
WetSaw
Absolutely!
But as it's only a shed being done up by the owner for their own use, and they've got the tiles already, I still say it's worth a punt. Certainly wouldn't advocate it normally but I would do the same in my shed if I was in this situation.
m3fitter
the adhesive / grout will cost you more than the tiles ! the glaze is too thin, and will wear off, chip... don't waste your time and money, as someone said, if they could be used on the floor, the manufacturer would have advertised it.. your call... also a wall tile biscuit cannot take weight as designed not to be load bearing and the tile will crack under pressure..
Reply to Wall tiles for floor tiles?????? in the Best Floor Tiles area at TilersForums.com
Hi, We are redoing our main bathroom and looking for a second opinion on tanking. We have bought...
Hi there, We have red quarry tiles in our indoor entrance hall and my wife would like to paint...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Wall & Floor Tiler Queensland Australia Tile Right About the role Seeking a Wall & Floor Tiler...
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
