Discuss Wall Tiles Not Sticking in the British & UK Tiling Forum area at TilersForums.com.
Tambo
Hi folks, hope you can point me in the right direction here :mad2:
I'm putting ceramic tiles on a ply faced wall (sealed with pva), using unibond waterproof adhesive. Trouble is, the tiles are sticking initially, but then 'pop' off the wall as they dry. Adhesive is sticking well to the wall, but the tiles are coming off virtually clean.
I'm applying the adhesive to the wall, and only covering about 2 tiles worth at a time. Tiles are 250x335.
Done quite a lot of tiling over the years, but never had this before !!
Any ideas ??
Cheers,
Tambo
doug boardley
Any ideas ??
Cheers,
Tambo
the highlighted text is your problem mate, pva is not a primer and should never be used as such. When you apply your adhesive it is bringing the pva "live" again, ie back to a liquid state. So in effect you're trying to stick your tiles to liquid!:thumbsdown:
kilty55
1,113
edinburgh
hi tambo,your tiles are as big as i would go using tubbed gear,however unibond tubbed gear i found was a poor quality adhesive and would advise against pva also. switch to a better make like mapei /bal/ pci and a suitable tilers primer from the same brand and i dont see you having any issues,the unibond seems to get mentioned a fair bit on here in the way and problems your describing mate:thumbsup: good luck
Aztectiler
I'm with you Doug. NEVER EVER USE PVA AS A SEALER:mad2::ban:
Tambo
:oops:
Got the pva message - thanks. Presume I can use the proper primer directly over the top ?
Bit that's confusing me is that the adhesive sticks really well to the ply (despite the pva), but virtually nothing on the tiles !!
Funny thing is, it's the neatest jobs I've done - right up until they're lying in a heap on the floor :yikes:
Many thanks.
Colour Republic
this was my thought, although you shouldn't have used PVA you did say the adhesive was stuck to the wall, you also said that you were only spreading enough addy to stick 2 tiles at a time, so neither the PVA or skinning of the addy seems to be the problem with the tiles falling off at this moment in time... so it must just be the quality of the addy.
are the tiles really dusty?
Tambo
is there a profile at all on the back of the tiles?
There's a diamond patern of ridges on the back.
Don't seem dusty at all.
As a keen amature (read moderate diy-er) my next thought was to apply the adhesive to the tiles rather than the wall. Know it's not the done thing, but it would answer the question - will it stick to the tiles. :dizzy2:
doug boardley
  1. that's your back profile
  2. that's called back buttering,quite common actually, but you still need to apply combed adhesive to the walls:thumbsup:
Reply to Wall Tiles Not Sticking in the British & UK Tiling Forum area at TilersForums.com
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
