Discuss Wall tiles to Floor tiles joint in the Best Floor Tiles area at TilersForums.com.
richardkear
Hi Guys,
what is the correct method of finishing of the joint between the wall tiles and the floor tiles?
Is it colour matched silicon as in internal corners or just grout as normal.
Tile wall first or floor first whats the preference
Wall tiles are 400 x 200 laying in brick pattern and floor is 450 x 450.
Just want to do the job right
Mike
if it's not a wetroom then it don't matter tile the walls or floor first but i'd do the walls first as not to risk damage/dirtying the floor. you must use silicon in the wall to floor joint to allow for expansion/movement, you can get a colour match silicon with most grouts. the internal corners of the walls must be siliconed too, and the ceiling gap must be caulked same as the architrave.
Mike
Thanks Mike and sorry to be stupid but.... 'Ceiling gap must be caulked same as architrave' huh? What do you mean.
i mean between the top tile and ceiling, it is best caulked (flexible decorators filler) rather than grout which would crack. also caulk the architrave as caulk is paintable. i mentioned in my first reply that i tile the wetroom floor before the bottom row of wall tiles as this will have less chance of leaking if the silicon fails as the wall tile overlaps the floor tile. that's my opinion anyway but i'm sure others have their own way
Reply to Wall tiles to Floor tiles joint in the Best Floor Tiles area at TilersForums.com
Hello, First post. Wish I had known about this forum several years ago. Here's my question...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hi, hoping someone can help with advice. We purchased 600 x 600 tiles for our bathroom floor...
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
